i have charger relay that is arching, is this common 0n. 1997 club car ds/ power drive charger
just saying hi newb, djlou
Thank you for your welcome matti. the casing on the relay has burned down or melted a little. right at the lead that comes from the transformer on the in put side or a/c side, also wire coming to relay from transformer is melted . i ordered the relay. i hope it fixes the problem. Problem being ,not charging, battery light comes on, some times the breaker trip's.i just was wondering if this is a common fault with the charger or is there some wiring issues.When i got the cart i found the cart was staying on and running with the key switch in off position.i switches the wires to the key switch and now it runs only when the key is in on position. but now i found the charging issue, could it be related or are they different problems? i wish i had a wiring diagram. I would love your input. thanks Djlou
Meltdowns within the charger are not common.
The service manual for your charger is here: http://www.golfcartsforum.com/golf-c...accupower.html
The wiring diagram for your cart should be this one: http://www.golfcartsforum.com/golf-c...g-diagram.html
