48 volt sensor line value for '98 club car
  • 48 volt sensor line value for '98 club car
    My charger will not allow the charger to activate. The 48 volt sensor line value for '98 club car is 35v and the + line is 47v. Is this normal?
    Rick
    48v Battery Charger for '98 club car
    How can I check the power relay in the charger. It dose not activate.Is there more than the relay itself that could cause this?
    Rick
    Updated by rick; July 27, 2011, 05:22 AM.
      '98 Club Car Speed
      Hi, Can I get more top speed by installing larger rear tires?
      Rick
      Updated by dougmcp; August 1, 2011, 01:37 PM.
        Club Car '98 48v and 12v fan
        Hi again, Can I add a 12v fan to my 48v system?
        Rick
        Updated by rick; July 27, 2011, 05:28 AM.
          '98 Club Car Brakes
          Hi, How easy is it to check my brake linings for wear?
          Rick
            Posted earlier by rick
            Rick
            You can bypass the relay to check the charger. What charger do you have (model #)?
              Hi, Can I get more top speed by installing larger reat tires?
              Rick
              Yes, the max size on a stock cart is 20" diameter.
                Rick
                Yes, you can attach to the 12v reducer if you have one or use 1 or 2 of your 8v batteries for your fan.
                  Rick
                  If you are having brake problems you will have to remove the drum to check the shoes. If you are just curious, it's a bit of work to do this.
