How To check for spark
  • How To check for spark
    First, remove the spark plug ground wire and unscrew the spark plug. Now insert the spark plug back into the ground wire. Finally hold the tip of the spark plug against a solid metal ground and attempt to start the engine. If you see a spark that means your golf cart has spark. If you do not see a spark try again with a new spark plug. If you still do not see a spark, that means your golf cart has a spark problem.
