How To Adjust Toe-In. Club Car Precedent as Example
  • How To Adjust Toe-In. Club Car Precedent as Example
    This may be something other "newbies" like me would be interested in. Ed S.
    Thanks for the information. Very helpful
      People can learn from this
        Thanks that did help.
          I like the write up, it would deffinitely dial in the toe to a much more precise degree than what I normally end up doing.
          If you are just looking for a quick fix, say after you install a lift kit; a straight ruler and two people is all you need. Just find the casting mark on the tires, or pick a point on both front tires, normally in the middle, and measure the distance between the tires, using the same points front and back. After that its a simple adjustment of the tie-rod ends until you are left with roughly 1/8" toe in, and there you go.
          Again, this is only a quick fix, and the OP has a much more specific and I find better way, yet it does definitely take more time.
            That's the way I have been doing rudimentary alignments as well.
