G1 Problem
  • G1 Problem
    My cart has started recently turning over real slow at first then finally speeding up enought to start..does the same in either direction..and sometimes u have to wait a few seconds before starting as it won't turn over at all..Also I don't believe my oil injection is working correctly. Does anyone know about after how many gas fillups untilI should need a oil fillup..
    Please help
    Replace the battery with a new one, since your current battery is worn out. Id say after running 2 gallons of gas you will see the level of the oil go down a bit. When you floor it or go up a hill you should see blue colored smoke coming out of the exhaust. This is the color the exhaust gets after gas is mixed with oil. But if you dont want to chance it, just premix your gas and oil
      Hey Thanks for your thoughts, but the battery is brand new, aND MORE THOUGHTS
        Hi what is the battery voltage before you press the pedal, and while you press the pedal and hold it?
