G5 bogs down hot
  • G5 bogs down hot
    I have a G5 gas that bogs down hot at times and starts to sputter and won't go. Is there a manual or info so I can check the fuel pump, coil and CDI?
    Thanks.
    Oh, I've cleaned the carb, checked compression and adjusted the valves.
    Updated by YamahaG5; May 15, 2010, 05:38 PM.
    Hello, does choking it help when that happens?
      No, not really.
        Posted earlier by YamahaG5
        Thanks.
        To test the fuel pump, take off the pipe that runs from the fuel pump to the carburetor and put it over a bucket. Now press the gas and fuel will flow out, if it does not you have a fuel pump problem.
        To test the spark, when the cart is acting up remove the spark plug and in a dark area hold the spark plug to a ground and press the gas, you should see the spark plug do a nice blue spark. Not yellow.
          I charged the battery very slowly, seems to run better now but it's charging over 16V. I think it needs a voltage regulator.
            A 16.2 volt reading is just fine.
