I Have A G8 That Smokes. Checked Compression, It Had 180 Lbs. Sounded Awfull High To Me. Could The Muffler Be The Problem ?
G8 Smoking
it puts out light blue smoke- to start with it put out a lot- i took plug out and put a little lucas in cylinder all night. turned over by hand several timed to coat cylinder wall- put in new plug. smoked bad at start-up untill it got lucas burnt out- now it hardly smokes at all. do you think it may have got cylinder washed dry and rings wasnt seating ?
Blue smoke is burning oil. If at one point it was smoking a lot, it will take a few hours of riding to get any leftover oil out of the muffler. So actually the muffler itself is making the smoke. If the problem stays after 5 hours of driving, I will look more into the fuel, type of oil being used, and if the valve seals are possibly letting the oil into the cylinder. To see, keep an eye on the oil level, if its going down that means you are burning oil.Regards
Posted earlier by HARRYJAWSOk- Thanks For Advice- I Was Gonna Try To Sell It If I Could Get It Not Smoking- Guess Ill Have To Invest A Little More In It.Regards
