G5 connecting rod torque specs needed
  • G5 connecting rod torque specs needed
    I need the torque specs for a G5 gas yamaha golf cart connecting rod and side cover. I have the specs for the head bolts and valve lash setting. any help would be greatly appreciated. thanks guys and gals.
    I do not have the repair manual so it wont be exact, but I can make a educated guess for you if you'd like.
      an educated guess would be better than what I have. My guess was 28 Ft lbs. and lock tite. what is your guess?
        Okay here it is. For the connecting rod caps, 13 ft/lb and lock tite. For the side cover, depending on the size of the bolts, 8mm around 13 ft/lb, 10mm around 15 ft/lb, and 12 mm around 18 ft/lb.
