The starter on my g16 died last fall. I had it rebuilt but just got around to putting it back on. Since it had been sitting so long I decided to pull the carb, spray it all off with some carb and choke cleaner, empty the float bowl and the old gas, and start with fresh gas. Now that I have put it back together, I cannot get it to start. It cranks fine, and I have spark at the plug. Here are a couple of things to point out in case they make a difference:
1. When I crank it (air box off) gas wants to blow out of the carb. Big mist blowing out of the carb, I can't imagine any blowing in.
2. When I choke it, it slows that some, but you can see most of the force is towards the air intake instead of into the motor.
3. I took the float bowl off but it is not keyed so I am not sure which way the bowl goes back on. Does that matter? It is round so I was not sure.
Thanks for your help.
