I HAVE A G2A THAT IS NOT CHARGING. HOW DOES THE CHARGING SYSTEM WORK? I'VE DOWNLOADED THE WIRING DIAGRAM, BUT I HAVEN'T FOUND WHAT DISENGAGES THE START SOLENOID AND STARTS THE CHARGE CYCLE. HOW DOES THE STARTER/GENERATOR SYSTEM WORK ON THIS MODEL AND HOW DO YOU TROUBLE SHOOT IT? I'VE ALSO NOTICED THAT WHEN USING THE HEADLIGHTS, THEY BURN BRIGHT AT LOW ENGINE SPEEDS AND DIM DOWN AT HIGHER ENGINE SPEEDS.
I DO APPRECIATE ANY HELP ON THIS MATTER.
