G1 base carb adjustment
  • G1 base carb adjustment
    I recently purchased a cabin in Wisconsin and it came with a 81 yamaha G1. i want to go through the carb and was wondering if what the base mixture and idle setting were. should i start at 3 and a half turns out and go from there?
    as a side note, i have been browsing this site and really enjoy the helpful members in here! thanks for your help ahead of time
    Eddie
    Hello Eddie. The idle setting is to be set as the flap fully closed when the pedal is untouched, if the flap is open even just a little the golf cart will backfire.
    The mixture screw is set at 1 1/2 turns out. Hope this helps
      Thanks Matti! that does help, i manged to also find a online user manual with wiring diagrams....
      Thanks again!
