Sometimes when I step on the gas pedal nothing happens on my 1997 G16 Gas Cart. No sounds at all. The starter has been rebuilt. This is an occaisional thing. Could this be dirty connection somewhere? Please offer some suggestions to try. Thanks.
1997 G16 Trouble Starting
I think I may need to explain the symptoms a little more. I step on the gas pedal the solonoid clicks the starter engages and trys to drive the belt but it's like theres not enough power to spin the motor & engage the clutch. If I move the cart forward or backwards it will go. The starter was rebuilt and the company told me they load tested it. Is there a min/max load rating? Could I have a dead spot on my crank? Could it be the clutch? Sorry for all the questions but it's frustrating.
Thanks,
Leanman
Oh I see. That is because your starter is turning but your engine is not running. This can be due to quite a few things but in order to test it you need to have some experience. It has nothing to do with the clutches.
Not sure why moving the cart forward and backwards makes the engine run again though.Regards
