G5 Starter Generator Pulley
  • G5 Starter Generator Pulley
    Does anyone know how to remove this pulley from the crank. Have mine torn down to here, but not sure how to get the piston out to rebuild.
    Thanks
    All things attached to the ends of the crankshaft usually have a bolt holding them in, and then they are held in by pressure. To break the pressure bond some people use pullers, others tap the center with a hammer, others just work at it until it pops off. Once the ends are off of the crankshaft, you can then unbolt the crank case. Hope this answers your question.
      Thanks, yes that does answer my question. That is how I thought it was but wasn't sure and didn't want to break anything. First time doing this sort of thing.
      Thanks again
