piston - cylinder clearance
  • piston - cylinder clearance
    Does anyone know the preferred piston to cylinder clearance for a rebuild?? (gas g-1 - should all b the same)
    Hello roggair, the maximum piston to cylinder wall clearance is .0020 inches (.050mm).
      Max for rebuilding? So what is the preferred spec? .0012-.0014 is what I heard, but that seems a little small for an air cooled engine... thanx Matti
        Posted earlier by Rogggair
        No that sounds about right. So what did you decide to do.. are you overboreing the engine to a larger piston?
          yea, just got the piston...had to go .030 over...I've got access to boring & honing equiptment, so it was easy....just looking for the finish hone spec...thanx again
            Glad to help.. Make sure you have the machinist measure the piston when honing out the cylinder, as opposed to giving him measurements.
              i am the machinist...
                okay
                  i am the walrus also, but that's a separate issue...
                    I'm not even going to question that one
