Im sure this cart will be running when Im long gone, its been a good one. With that being said, after replacing the 7 yr old battery, I decided to do some maintenance, Ie oil change, air filter, spark plug and rear end fluid.
So Im having issues getting the rear differential to take new fluid? I located the drain plug but no fluid level plug? I read you put new fluid in the vent hose, so after I used a wire to break up mud dobber nest in the tube and cleaned it the best I could. So the issue im having is the fluid wont go it through the tube, I believe its because there is no vent or I cant find the fluid level plug? I cleaned the housing and can not locate the plug? help
