i have a 1999 g16 that want charge the battery. i took the generater to a repair shop and they said it was ok. i need some help! can anyone give me any advice?
g16 yamaha gas cart want charge battery
Your voltage regulator is a little box with 3 wires coming out of it, usually near the solenoid. To test it put a voltage meter on the battery mains, jack up the rear of the golf cart and run it at full governed throttle. If you are getting a reading under 12 volts your voltage regulator is bad.Regards
Np, It goes in this order. Generator > Voltage Regulator > Battery. If the voltage regulator is not operating it will cut power to the battery in your case, so your battery will not charge.
You are looking for 13-15 volts on the battery at full throttle for a few minutes. Dont unhook the battery.Regards
