Replaced bad battery and now won't start
  • Replaced bad battery and now won't start
    I replaced my battery in my 2003 gas Yamaha today and I sparked a wire lightly while doing so. Now the lights work, but the starter won't turn over and the backup buzzer doesn't come on in reverse either. Is there a fuse I need to replace? I found a 15 amp fuse on a cable right by the battery and it was ok, but I am wondering if there's another one and where is it located.
    There is a 10 amp fuse you can check which is on the negative cable inside the electronics cover, it is a fuse that runs off battery negative and A1 post on the starter/generator
      I am attaching the g22a wiring diagram to this post with the fuse highlighted for reference
      This gallery has 1 photos.
