Yamaha G15 multi person vehicle
  • Yamaha G15 multi person vehicle
    Hello Here a question from Holland
    I bought a G15-A Golfcar its a 4person model , he wont start and i find a connector with 3 wires and one of them is melted away the black wire
    I think its the cable that goes to the engine ignition pickup i'm not sure because i can't see where the cabe is going to and i cant find a wiring diagram for this type.
    The question is can sombody help me with a wiring diagram or a comlete manual so i can try to find and fix the problem
    Kind regards and greetings from Holland ( Europe )
    Willem Jan
    Welcome Willem, Probably a short in the wires somewhere, I will let you know on the owners manual these Japan built models are very rare.
      Hi Matti
      I Hope you can fix a manual for me because eveything i tried doesn't work so youre my last hope
      Greetings from Holland
      Willem jan
        Hi can you give me your serial number on the golf cart?
          Hi Matti
          Here is teh seriel number JN5 0002317
          Thanks so far
          Willem Jan
            Hi Matti
            the number was wrong
            It has to be JN5-002317 as you see there was one zero to many
            Rgrds Willem jan
              The only three wire bundle on a G-15 is the wiring going to the coil. RED,ORANGE,BLACK. A missing ground on the lower black wire on the starter is prone to failure. It is a 16AWG wire with mating butt connectors )which come loose). Note: Yamaha fuses the ground side. Check both fuses and the small black wire on the starter. It should read 0 ohms to the frame.
                G 15-A to my knowledge has a Yamaha G16 engine. Pls. proceed from this info.
