I have a 1999 Yamaha G16 gas cart with a sizable hole in the rear differential cover. Can anyone tell me how to remove the differential? Do I have to remove the cart body first? Thanks in advance for your help.
Rear Differential
Hey Wade!
You couldn't pull the differential out from the top since the frame goes over it. You would have to drop the engine cradle, remove the rear mounts and shock mounts along with the drive belt and connections.
Is there no possible way you can access this cover with out removing the whole rear, or did you break something within it?Regards
