G9 with wiring problems
  • G9 with wiring problems
    Hi everybody, please help me with my 1991 Yamaha G9. I bought it used, the starter generator was the wrong one, off a cub cadet, would not charge the battery, so I replaced it with a proper starter generator and new voltage regulator and first thing it did was smoke the black wire going to the pickup coil in the cylinder head, as I took all the wiring off to inspect and cannot find out why.....anybody know why....thanks
    Hello wrfd15! Something is wired up wrong, did you confirm your wiring with the diagram in the diagrams section?
      Yes I did, but it was not clear on a few things, like now I think the problem is the negative battery cable was going to the frame for ground, as the picture of the wiring shows it going to the A1 terminal on the rear of the starter generator, makes me believe it grounded wrong or not enough, but since this posting I have not had time to try that as I have been working alot...but will try and let everybody know if that worked...thanks
        Okay let us know
          where do I find the wiring diagrams sections, I could not find them...please advise...thanks
            Here is a link http://www.golfcart-forums.com/golf-cart-diagrams/
            you can find the section on the home page.
              I found it, thanks alot
                Yeah guys, I fixed the problem, I moved the negative ground cable from the housing to the rear of the starter generator marked A1 and also grounded the wiring harness to the same negative terminal and it works like a champ....thanks for the help
