G2yamaha
  • G2yamaha
    My cart starts and runs good until I stop, and will not start until it cools off takes about 10 min. Has anyone seen this and what was the problem.
    sounds like you may have an coil problem or a igniter problem. also check to make shur all your grounds are good and clean. also run a ground wire from the battery to where ever all those grounds meet up.
      I have seen this problem at least a dozen times and it was old Fuel and vacuum lines once they get hot they collapse cutting off your fuel pretty cheap fix probably needs done anyway just a suggestion good luck
