92 yamaha
  • 92 yamaha
    When I press accelerator nothing happens but I can jump solenoid turns over if I jump solenoid and push accelerator it runs I checked stop switch getting to and from key switch has power had all wire exposed no broken everything grounded getting power to solenoid from battery large post no power going out to starter even unplugged back up buzzer to reset nothing I got on repairmanuals.com tried to order repair manual said serial number invalid
    when you say jumped solenoid are you jumping the small terminals or the large terminals.
      using your volt meter set to volts, leads on small terminals of solenoid and pressing gas pedal do you read voltage.
        Posted earlier by gaminde
        large
          just on one side so I changed solenoid stil same just one side
            Posted earlier by krg1212
            I'm sorry I do not understand one side of what ok I see there are two posts.
            We need to slow down and do one thing at a time
            put your meter on the small terminals and press the gas and read voltage.
            Updated by gaminde; July 11, 2013, 07:57 AM.
              I was on the Yamaha site and there are no G6's in 92 per there manuals
              So here is a 92 G8 schematic
                I check voltage at solenoid looks like 9 volts on both small terminals
                Updated by krg1212; July 11, 2013, 08:38 AM.
                  you need to follow what Im saying
                  there is no 9v on both terminals
                    nothing
                      Ok lets see if we can get someone who knows about Yamaha gas I have no clue don't like gas to noisy.
                        can you post the serial number of cart?
                        then we can get a wiring diagram and start from there.
                          Thanks Wthompson
                          • #14
                            ground wire on connector to solenoid bad, cart up and running, really thankful to you all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                            Updated by krg1212; July 12, 2013, 08:15 AM.
