Hello everyone. New here. I just bought a handfull. thought it was a good deal but am finding that this might be a big project. it had a bad muffler, replaced that. easy one. now i have some grinding, metalic noise coming from engine/clutch. I grabed the end of the primary clutch and there is some up and down play in it. i checked the crank seal and that seems to be fine. (engine did not rev when i sprayed wd-40). The noise is loud enough that you can not have convo while riding on it. Could this be anything other than a crank bearing? is this a tough job to change?
Thank You.
From Minnesota.
Thank You.
From Minnesota.
