No action from the starter
  • No action from the starter
    I have a G2 Yamaha gas unit that the only problems have been with blowing the fuzes on rough terrain. One got replace with a 25A rather than a 10A, now the fuzes are fine but I get no action from the starter. I have electrical power. What did I fry, the voltage regulator? the relay?...any ideas?
    Updated by driftwood; May 17, 2008, 06:56 PM. Reason: spelling
    Fuse problem: Check all connections on the solenoid and everywhere for a loose/dirty/cut connection, chances are you were blowing a fuse due to this.
    Current situation: When you press on the gas do you hear a click?
      I do not get a click.
      I also blow the fuse if I connect the battery with the fuse connected.
        you may have did something to the solenoid by upping the fuse amp....hats why they use a certain amp to protect the compontant.....................
        Tom
        if i didn,t like them so much i wouldn,t touch them...........
