I had worn brushes so I replaced the brushes and sanded the armature. Put it all back together and the starter spins great until i put it under a load to turn over the engine.
I figure the battery was just warn so i purchased a new battery and the same issue. The starter will turn the belt but very slowly and not fast enough to turn over the engine.
I held the gas and the area by the brushes smoked a little but it finally turned over and ran fine.
Now when I press the gas sometimes it is very weak and will not turn the motor. I just press the gas 2-3 times and it will finally catches and sover fine.
Is there a break in period for the brushes or some type of process to wear there is?
Thanks for your help...
