My dip stick from my G16A cart came up missing. I noticed oil dripping from under my cart and after checking it appears that oil is spraying out of the dip stick holel. I could have just lost the dip stick or someone needed it worse than I did.
My question is, should oil be spraying a mist out of the dip stick hole? Is the crank case pressurized? Is the fix as simple as getting a new dipstick or could the dip stick have been blown out due to pressure in the crank case that shouldn't be there.
Thanks for any help.
