I am working on a G-2 that loses it;s spark at about 3/4 throttle. After the RPM's come down alittle the spark comes back until the RPM's get high enough again then the spark drops out again. This is a never ending cycle. I have replaced the ignitor unit but it didn't change anything. The pick up coil test ok. I put an extra ground wire from the engine to the ground terminal on the battery, still the same. Where do I go from here?
Thanks Woody
Thanks Woody
