stalls on hills
  • stalls on hills
    I have a golf cart that runs fine on level ground but stalls pop and sputters when going uphill. I have two that are doing this and was wondering if you all had any input.
    sounds like water in the fuel bowl, you put gas in it from a gas can? check your can.
      Sounds like govenor ptob.?
        Along with the other 2 answers low fuel level in the float bowl, adjust your float level.
          i need a diagram for yamaha g16 gas golf cart
            DOes ayone have a good step by step rebuild video?
              If you have two doing the same thing, I would check the gas. Need to use high octane.
                Posted earlier by jcg9
                Why High octane? Just curious. Thanks
                  because the fuel systems on the earlier carts are not made for the alcohal that is in your unleaded fuel, the premium has no corn in it, at the course i maintain the carts at we have had no carb problems after going to the premium fuel
