where are the fuses
  • where are the fuses
    I can't get my cart to crank. It is completely dead.
    I hear there are fuses somewhere, but I can't find them.
    I looked under the diagrams section of the forum, but since I am on a phone I can not read them clearly.
    please help.
    you have 2, both are inline close to the battery, under the solonid cover?
      Here is what i got so far:
      I can disconnect the battery and reconnect it and the cart will run and the radio will work for a short period of time.
      then if you stop the cart it will not crank.
      Battery is still at almost 13 volts, 12.7 to be exact.
      It is sort of like something is heating up and making it shut down electrically.
        pull the mat back on the drivers side, lift the plate out, at the top of the go pedal there will be your stop switch. check that for voltage, if that plug gets water in it it wont start. blow the connections out and fill with di-electric grease, never have that problem again.
