Anyone have any experience with or opinions about installing a G22 357cc motor in a G14?
Engine Swap
OK, if no one has anything on that swap, how about this?
A 24HP 688cc V-twin Honda with a complete kit that requires no cutting or welding to install. It is made specifically for all G14 thru G22 carts. I REALLY like this one, but it is quite pricey!
Plowmans Carts are pretty reputable for motor conversions and maybe you should give them a call, Don at 810-736-1100.
Depending on what you're looking for, here's one that is a little pricey too but has 28HP and will go 45mph with stock gearing. http://www.plowmanscarts.com/hp_v-twin.html
I just got through talking to the mechanic at my dealer about the 357cc engine swap. He has already done them, using new engine units. The only notable mod that needs to be done is to swap the locations of the battery and fuel tank.
I'll be scheduling mine to be done sometime after the first of the year.
Posted earlier by StoneyI just got through talking to the mechanic at my dealer about the 357cc engine swap. He has already done them, using new engine units. The only notable mod that needs to be done is to swap the locations of the battery and fuel tank.
I'll be scheduling mine to be done sometime after the first of the year.Regards
I spoke with the dealer mechanic today about the 357cc conversion in older carts. He said it can be done on all G2 thru G16 gas models with the G16 being the easiest model to do.
Unfortunately, after pricing out all the parts(new) and adding labor and tax, it was right at $3K+. Looks like I will pass on the conversion unless my 300cc takes a dump.
Posted earlier by StoneyI spoke with the dealer mechanic today about the 357cc conversion in older carts. He said it can be done on all G2 thru G16 gas models with the G16 being the easiest model to do.
Unfortunately, after pricing out all the parts(new) and adding labor and tax, it was right at $3K+. Looks like I will pass on the conversion unless my 300cc takes a dump.Regards
