94 G9 Wont Start
  • 94 G9 Wont Start
    I Have A G9 That Wont Start. Have Replaced The Igniter, And Coil. Still Nothing. Everything Ohms Ok. But Manual Doesnt Say What My Voltages Should Be At The Coil And Out Of The Igniter. Can Someone Help??
    I do not know the voltages, but pull the spark plug out, hold the firing tip of the spark plug against some ground source and press the gas pedal so that the engine tries to start. There should be a nice blue spark coming from the spark plug.
      It Has No Spark At All With A Dynamic Tester. Any Suggestions.
        You may not want to hear this because it is a lot of work.... check all the ground wires including the RPM limiter. If the RPM limiter failed it could be grounding out. If that checks out OK you have a ground that possibly pulled apart or a broken wire somewhere.
