My cart runs fine once I get it going, then once it sits I get back on it push the pedal and it clicks. I tap on the starter then It goes. Is my starter going bad? Thanks
Yamaha 1996 g14 runs fine but sits and won't start
Updated by Far_bynd_drvn; October 11, 2011, 03:37 AM.Tags: None
If you have lights, turn them on, and then try to start the cart. If the lights dim dramatically, then your battery is bad (this is a down and dirty battery load test). If the lights don't dim, just the solenoid just clicks, then it is probably the solenoid / starter. You can also try tapping the starter to see if it catches. Every battery looses it's charge by some degree as it sits. Unhealthy batteries loose it VERY quickly.
RAH
