I have a 2010 Yamaha drive. When I put on the brakes, it sounds like a rattle in the hub. Any thoughts?
brake rattling noise on yamaha drive
Hello, 2 choices. Take it back to the dealer and have them service it under warranty. Or jack up the cart and remove the rear tire and brake drum and have a look. Make sure the brake pads are tight, check the axle bolt that it is tight and if there is a cotter pin, make sure that didnt come out.Regards
Posted earlier by ronfarnellI have a 2010 Yamaha drive. When I put on the brakes, it sounds like a rattle in the hub. Any thoughts?
How long has this been happening?
Do you have hubcaps?
Custom wheels?
Hard surface road, soft surface grass or both?
Are the lug nuts tight?
