I have had my starter/generator repaired and replaced one bad solenoid with a replacement aftermarket solenoid. My problem;
After I hook everythng up, when I place the battery negative cable on everything is energized. The key is turned off but the starter /generator cranks at full speed. The unit does not start, I assume because the key is still off an the gas pedal is not depressed. Looking for some direction. I replaced all the wiring exactly like I removed it. Or so I think! Thanks for any info anyone can provide.
