I have a 2000 yamaha gas cart. I used it to go down the street and then on the way back I stopped for cars to go by and went to start going again and had nothing at all. I step on the gas pedal and there is absolutely nothing. where should I start to look. the battery is good.
yamaha won't run
try looking under the floor mat where the pedal isand see if there is a panel that will lift up . then check where the pedal is and see if there is a stop switch . take a screwdriver and tap on it while you push on the pedal . i have an older golf cart and it worked for me . the tech told me that they dont go bad but pluges up with dirt .
