i just picked up a yamaha g14e and i am trying to get it going to use as a pit car at the drag strip, it does not have either diode for the harness can i build a diode to get by what size should i get at radioshack?
also this is supposed to be a 36v car and it came with 6 trojan batteries all intacked and i checked the charged voltage and each was at about 8.4v which added up to 50volts should i remove 2 of the batteries to get it down to 37-38 volts, everything else appears to be 36volt.
