Bought at garage sale, cheap
owner got hung up on a stump 3 years ago once off it would no longer run, has been setting in weeds all that time.
It is now all over the yard, porch & dining room table, nothing to taking a Yamaha to pieces. Have cleaned all connections and replaced batteries, cables and solenoid. Motor will operate when it is jumped, most switches activate as should except the ones in the wiring harness that goes into the controller, they read voltage, if they are grounded. There are 2 diodes both are the same and are good, diode(B)reads 38 volts. Diode(A) I can jump across and it reads, using the volt meter it reads without the diode in. Once I put the diode in I get a reading of .3 key on .7 acc depressed in both F/B. This diode goes to the solenoid but also the same wire goes to a switch I have to jump across. Any ideas????
