These maybe some dumb questions, but I don't know anything about golf carts and recently came across one. Here is what I know, the body has Yamaha across the front, on one of the pillars it has a serial number tag, with no model or serial number that is visible, it does say Taylor Dunn, it has 6 batteries, the charger plug for the 6 batteries looks like a V that doesn't touch at the bottom. I don't have a charger, so I don't know if the info I gave you is enough to determine how many volts. Please help me, if you need any info just let me know where to find it and I'll get it. Thanks
Don't know anything and need your help
Here is a time line that could help you out http://www.yamahagolfcar.com/corpora...rtimeline.aspxRegards
If I were to pick one, it would be the Yamaha G-9 Model (Fleet Master) Golf Car, it seems that it is the only one that has plastic side covers that go up the seat. Mine has a top on it, don't know if that was an option or not. So, with that pretty much determined. What type of charger do I need? Are all 36v the same? Are all plugs the same?
Now that you think you know which yamaha it is, you can use this to find the exact location of the serial number http://www.golfcart-forums.com/golf-...golf-cart.html
If the previous label you were talking about earlier turns out to be the serial number plate and it is worn out then you may be out of luck.
Any 36 volt golf cart charger will work, it must have the g1:g2:g8:g9 plug on it.Regards
If hooked up the the right plug, could this be used for my golfcart?http://cgi.ebay.com/Mastech-Universa...3A1%7C294%3A50
