My 48v 2001 G19E suddenly stopped working in forward, only in reverse. Has anyone else experienced this & what the problem is?
Yamaha G19E only goes in reverse
You might want to start by checking the connection at the controller plug. It’s possible that a loose or poor connection there could be affecting the cart’s ability to move forward. Try gently moving or wiggling the plug and see if forward function returns, that could help pinpoint whether the connection is the issue.
Another thing to consider is your forward and reverse switch. Some carts don’t have separate inputs for forward and reverse, but yours does, which means a faulty switch could be causing this. To test it, look at the wires on the back of the F&R switch. The outer ones control forward and reverse, while the center wire provides power. If there's an issue with this switch, it could explain why reverse works fine, but forward doesn't. If you have any specific questions feel free to ask!
