Model: 2007 YDRE 48V with 4each 12V batteries.
Whether or not the ignition key is in the cart or not. With the switch turned in the off position, I can depress the accelerator pedal, and the cart whines.
When the key is in, and turned on, It will run/accelerate, and will even do pretty well as long as I keep the batteries charged.
It's when I stop that I realize there is a problem. The aforementioned whine continues even with the brake fully engaged. When I switch the cart to Tow Mode, the solenoid deactivates, and the whine ceases.
After I put the Tow switch back to Normal Operation, the solenoid re-engages.
I have tested the ignition switch, it is working normally. I have double checked the battery wiring, it is correct. I have ensured all connections are tight.
Any hints, advice, or opinions are deeply appreciated. I have waaaaaayyyy too much money in this thing to not repair it.
Thanks in advance,
Klell
Thanks in advance,
Klell
