Hi there. I have a 2005 g22e and i put in a new controller from alltrax. Everything works good now as it should except when i am switched in forward it goes backwards and the buzzer goes off and vise versa. Could this be an reversed wire? Do these machines go slower in reverse ao even if i switch a wire ill go slower in forward? Thanks !
Forward/reverse backwards
Yes, it sounds like you’ve got a reversed wire issue. To fix this, you'll want to switch the cart into tow mode first for safety. Then, simply swap the F1 and F2 wires on the motor. This will reverse the direction of the motor and should correct the issue where forward is reverse and reverse is forward.
As for speed, yes, these carts are typically programmed to go slower in reverse. Once you switch the wires, you'll have the proper speed in forward, and the cart will operate as it should
