Yamaha electric
  • Yamaha electric
    It want do anything when plug up charger lights on charger want even come on . How do you check control panel to see I feel if it is bad I have power every where
    If your charger isn’t powering on or charging the cart, the first thing to check is whether the charger has a fuse. If this fuse is blown, it would prevent the charger from operating, so replacing it might solve the issue. Also, take a close look at the charger port plug on the cart. Check to make sure it's not obstructed, damaged, or filled with debris, as any of these could interfere with the connection between the charger and the cart, preventing it from charging.
    Additionally, verify that the home outlet you’re plugging the charger into is functioning properly, as a faulty outlet could also be the source of the problem. This should help you identify whether the issue lies with the charger, the cart’s charging port, or another part of the charging system.
