Where is the fuse on a Yamaha G-Max G22E
  • Where is the fuse on a Yamaha G-Max G22E
    I know I blew the fuse on my golfcart but I can't find the 3amp fuse. The wiring diagram clearly shows it, but I can't figure out where it is. Does anyone know where this fuse is?
    The 3 amp fuse you're searching for is located in a weatherproof fuse holder within the factory harness, near the solenoid/controller. This fuse holder is designed to protect the fuse from the elements. The fuse itself looks like a 3 amp automotive style fuse but is about twice the length of a standard fuse you might be familiar with. To find it, follow the wiring from the solenoid or controller, and you should come across the factory harness where this fuse holder is integrated. If its not visible, it might be tucked away or covered by other components, so you may need to move a few things to find it. Once you locate the fuse holder, you can open it to check and replace the blown fuse.
