need to know where each of the 3 wires coming off controller lugs gose to
97 yamaha g16 need wiring help
i have this diagram but im having a hard time understanding it on my cart the controllers mounted right below the f/r switch on the drivers side i have three lugs sticking out of the controller what im trying to figure out is where each wire goes from each lug. Thanks for helping me
to be honest im new to the golf cart thing this may be the throttle sensor the wires going to it with a white band green band and yellow band they were unhooked when i got the golf cart it appears one goes under the cart to the motor the other two may go to the other side of the battery... i dont know and if i have them on the right lug and where the other two go
i,m not sure the three cables coming of the controler are in the right place. some one has removed these untill these are in the right place i cant see the cart moving. batteries are good all cables are good. i have no power to the key switch or to the switch behind the pedal. i do have power to the reverse buzzeri have some other thing to check but dont think i can be sure untill all wiring is in the right place.
made a drawing to try to help. if i am reading the diagram right one cable coming from the motor (a2) goes on one of these lugs. one from the neg. side of the battery. one from the f/r switch the same place a cable comes from the selenoid. correct me if i am wrong. the drawing show these lugs 1,2,3 which one goes where i dont know hope this helps thanks for all the help controller.bmp
Posted earlier by fitzmattSO how do I jump the solenoid? I am having similar problems and trying to figure if it is the batteries or controller or solenoid.Regards
Posted earlier by rredwineto be honest im new to the golf cart thing this may be the throttle sensor the wires going to it with a white band green band and yellow band they were unhooked when i got the golf cart it appears one goes under the cart to the motor the other two may go to the other side of the battery... i dont know and if i have them on the right lug and where the other two go
Posted earlier by rredwinei have this diagram but im having a hard time understanding it on my cart the controllers mounted right below the f/r switch on the drivers side i have three lugs sticking out of the controller what im trying to figure out is where each wire goes from each lug. Thanks for helping me
