i need some advice to get this cart up to say 20/22mph
need more speed from a 2008 g-29 electric
With the stock controller you could consider buying the speed code, more info on that here. If you don't want to go through the hassle, you could always swap out the stock controller for an Alltrax, which you would be able to adjust and control yourself. Remember not to put too much power to the motor until you upgrade that as well, as they were weak links, 19mph shouldn't overheat it though.
