Cart will roll away without slowing
  • Cart will roll away without slowing
    1999 JN8: Yamaha G16ET: 36v: Changed Controller, Cart picks up speed when going down hill with foot off accelerator. Any help what to check?
    Yes series golf carts like your 1999 Yamaha G16E typically do roll freely when you take your foot off the accelerator. This is because there’s no inherent braking mechanism or regenerative braking that engages in a series wound motor setup. So, it's normal for your cart to pick up speed going downhill with your foot off the accelerator. To manage this, you should first check that your mechanical brakes are in good working order and properly adjusted. You can also explore some lesser known options to help control downhill speed. For example, reducing the tire pressure from 15 psi to around 10 psi can increase rolling resistance a little which may slightly help slow the cart down along with giving you a softer ride.
