Yamaha G22E Electric wont run. First it would Randomly cut out and then when I flipped Run/Tow switch it would come back on again. Then it only ran in reverse and the Solenoid would just click in Drive Mode, Then it would die reverse with weak buzzer and you would have to flip Run/Tow a million times for it to even go in reverse.Now nothing at all. Checked fuse next to solenoid in wire harness it good. Motor tests good. New Controller and Accelerator stop switch.
No Reverse Beeper or Solenoid Click. Battery's all Have Full Voltage and test Good. I'm thinking it has something to do with the Pin Connector wire harness that plugs into the controller and has 2 little wires that plug into the run/tow switch it hooks up to the Potentiometer and Accelerator stop switch under the floor.
what do you guys think it could be?
Matt
Matt
