I have a reconditioned 2008 Yamaha Drive that is in excellent condition. My only problem is that the cart bounces significantly when on a street. Not noticable on course. Have already replaced tires. Any suggestons.
2008 Drive Bounces
Here is picture of cart.
What tire pressure are you running, Yamaha recommends 20 psi.
Both low and high pressures can cause bouncing.
Check the tires for roundness by jacking and rotating the tires with an indicator to check for an out of round condition.
Posted earlier by EarlKI thought of tires, changed all 4. Have been using 22 pounds, will try 20. I will try to check axles and hubs.
Changing tires doesn't guarantee roundness.
You may also try rotating front to back and see if it changes anything.
How fast is your cart?
Also, pull off the rear wheels and check the end axle bolts to make sure they are tight under each hub. Also check to make sure all your bolts, motor mounts and case mounts are all tight. Maybe vibrated loose. If all else fails, put it on a lift and take a detailed look from the underneath. Maybe have someone press the gas while someone looks from under it, be very careful.Regards
