Starts and Stops
  • Starts and Stops
    I have an '87 Par Car. The motor has been completely rebuilt, including ignition module and coil. It ran prefetly util lately. Start,stop,start,stop I put an in-line spark tester between the coil and spark plug. Pust the gas pedal I have a brilliant light in the tester and it fires right up. It runs for about 30-45 seconds the test light starts to flash dim and the motor quits. If you keep the gas pedal down the test light barely glows. Let the gas pedal completely off, wait a few seconds depress the pedal I get a brilliant flash on the tester. The motor fires right up, runs for about 10 seconds then quits. Let off the pedal completely then press down again, brilliant flash on the tester. Fires right up runs for 10 sec then quits. then this happens over and over again 10 seconds ,10seconds
    Please I need help. Flustered Steve
    If anyone has this same problem I found the problem. Did a few tests and found it to be the ignition module.
