Software:
EVolution Controller Software Download EV48-400, EV48-400-A and EV48-400-C
Posted earlier by harleydave@cox.netI can download the EV48-400-C file for my new 2024 Evolution Classic 2 Plus golf cart zip file, extract it and my HP laptop “Security” will not let me run it. Any thoughts here?
Posted earlier by golfcartg
It might be as simple as just right clicking the installer and running it as an administrator
- Likes 1
OK, I am a newbie to this forum, and I feel a bit like a “begger” for information but, here goes… I am seeking “settings” for increasing both the low speed and high speed settings on my new 2024 Evolution Classic 2 Plus golf cart. Our golf cart is a Low Speed Vehicle, fully licensed and insured. My wife and I live 2-1/2 miles from our golf complex. We travel on a 35 mph street, going 25 mph while traffic is running closer to 45 mph. Is there somebody out there that has made these types of speed increase changes and could forward that information/settings to me, so I do not have to reinvent the wheel thru trial and error.
Posted earlier by harleydave@cox.netOK, I am a newbie to this forum, and I feel a bit like a “begger” for information but, here goes… I am seeking “settings” for increasing both the low speed and high speed settings on my new 2024 Evolution Classic 2 Plus golf cart. Our golf cart is a Low Speed Vehicle, fully licensed and insured. My wife and I live 2-1/2 miles from our golf complex. We travel on a 35 mph street, going 25 mph while traffic is running closer to 45 mph. Is there somebody out there that has made these types of speed increase changes and could forward that information/settings to me, so I do not have to reinvent the wheel thru trial and error.
evoster
- Likes 2
OK, I have successfully connected my HP laptop to my 2024 Evolution Classic 2 Plus. When I first plugged the cable into laptop, it recognized the cable. Everything looks perfect, except… I cannot “connect” laptop to vehicle. Missing a “driver”? Any thoughts here?
Go to www.ftdichip.com/drivers and select D2XX Drivers
On the FTDI drivers page, the "D2XX" driver refers to the specific set of USB drivers designed to interface with FTDI's USB to serial (USB to UART) converters. The D2XX driver provides direct access to the USB device using a custom FTDI API allowing the application to communicate directly with FTDI chips without requiring the traditional Virtual COM Port (VCP) method.
Thank you for all the information. I am embarrassed to say my issue was “operator error”. After installing the driver, from previous conversations, I failed to shut down my laptop and then restart. After the restart, I now have 100% communication with my vehicle. A big sigh of relief, and again, “Thank you” for supporting a fellow, lost sheep thru this process.
- Likes 1
The “lost sheep” is here again. I have full communication with my new 2024 Evolution Classis 2 Plus golf cart controller. I have “fooled around” with numbers in multiple categories, with no success. I have re-changed all of the “fooled around” numbers back to original numbers. My question; Is there somebody out there that knows what menus/categories/numbers can be changed to gain more speed?
Posted earlier by harleydave@cox.netThe “lost sheep” is here again. I have full communication with my new 2024 Evolution Classis 2 Plus golf cart controller. I have “fooled around” with numbers in multiple categories, with no success. I have re-changed all of the “fooled around” numbers back to original numbers. My question; Is there somebody out there that knows what menus/categories/numbers can be changed to gain more speed?It sounds like you’ve been having some fun experimenting. It’s possible the dealer has already maxed out the RPM and speed parameters. If they’ve already set these values to their highest allowable levels, there may not be much room left to gain speed just by adjusting numbers. If not, make sure any new settings are saving properly
The “lost sheep” would like to whole-heartily agree with your assessment of my situation. Motor RPM’s are/were maxed out at 6,000, by the dealer. The software gives me the ability to adjust torque levels at different RPM levels and also adjust the ReGen braking. Disappointed I cannot squeeze out a couple more mph, but still enjoying our new golf cart. OK, software and speed are now in the rear view mirror. My next puzzle to solve is… a DoorWorks, hinged door installation on my new 2024 Evolution Classic 2 Plus golf cart. My wife and live in Las Vegas, winter is coming. I have the DoorWorks parts/pieces/instructions laid out in the garage. Are there any “special” hints/instructions that could assist me, prior to me digging into this task? Finally, a “Thank you” for rescuing a “lost sheep”, now found!!
- Likes 1
Also working through the tuning process. I have downloaded the EV48-400-C file for a 2024 Maverick D5 6 pax. When I open the app and attempt to connect the app to the cart, I get the following error "Serial port connection failed: Please try to connect other serial ports manually"
Any ideas? Usually a Mac user, haven't been on a PC for 20 years.
Thanks in advance!
This gallery has 1 photos.
Posted earlier by sloaterUpdate: So I refreshed the serial port per the instructions and it does allow me to connect, or proceed without the error message. When I go to the home page, the metrics are not changing or being registered.
- Likes 1
Good Evening All.
I just recieved my cart cables cable for my Forester 6 seater cart and realized my controller is the EV48-400-A. I downloaded and installed the software from the beginning of the Thread. (in Chinese even though it was labeled English). it is saying no license. I have the license number but cant seem to find where I am supposed to enter the number. Any Ideas?
Posted earlier by coysniderGood Evening All.
you can also try activating it using the following- open notepad
- paste the following code
- save the notepad titled “EvolutionActivation.reg” and save it to your desktop
- find it and double click it to run it
- click yes when prompted
Code:Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\EVCTRL] @="" [HKEY_LOCAL_MACHINE\SOFTWARE\EVCTRL\Programmer] @="" "Key"=dword:00000001
Yup, problem solved, program is up and running. I also needed to answer this Windows Defender warning several times; “Do you want to let this program make changes to your computer?” I was brave, said “Yes”. Up and running thank you, many times over, Thank you!
Posted earlier by enizzle
It didn't work for me. any suggestions?
Unzip file to folder;
Run on EVProgrammer.msi,Select installation path (normally it should be C:\Program Files (x86)\EVCTRL\EVProgrammer);
Copy License –“XXXXXX.flic” to the installation folder from step 2;
then copy “ACS1-20210427-1-E-C.fdev” to the same folder;
install driver files "CH340 CH341Driver.exe" & "PL2303_Prolific_DriverInstaller_v1.12.0-new-UGREEN.exe";
OPEN C:\Program Files (x86)\EVCTRL\EVProgrammer\EVOLUTION.exe , Run as Adminstrator
